I would appreciate if anyone can let me know what is the easiest way to bolt a bearing with 5mm ID and 16mm O.D onto a piece of wood so that it stays in place while allowing a 5mm shaft to rotate. I have attached a photo of the component if that helps. Would putting the bearing inside a 16mm shaft support mount and bolting that work?
Bearing
Mount
Bearing
Mount
