I have purchase bolts for my company, but I have only specify the material (AISI 4140). This is because we have calculated that in the annealed condition it would work well. But I have read in some paper that this material could be use or could correspond to bolts - Grade 8. I know that AISI 4140 corresponds to ASTM A193 Grade B7, that has less yield stress than a Grade 8. So I would like to know in what condition (heat treatment or anything else) it corresponds to ASTM A193 Grade B7 and in what condition it corresponds to Grade 8.
Everytime I purchase a bolts I have to specify the Grade or it is only necessary to specify the material (but I do not know in what condition they sale the bolt) so what is the right method. Is possible to obtain different grades than the comercial ones with the same materials or the manufacturers only follows the standard (in this case AISI 4140 would only be manufactured as A193 Grade B7).
Thanks in advance. I will appreciate a lot your repply, because I get a little confused with the theme. Bye.
