This is an outline form of our tube bundle parts:
Tube Bundle:
- Tube 1:
Fins
- Tube 2:
Fins
- Tube 3:
Fins
- Header (upper):
Pipe
Cap
Weld Flange
Couplings
- Header (Lower):
Same as upper
Each "-" represents a sub assembly and then they are all brought into the tube bundle assembly.
I need to create a drawing of the tube bundle (easy enough), but I also need to detail the headers and tube assemblies.
My problem is the BOM is based off the tube bundle assembly, but when I RMB click > drawing views > model and insert either the upper or lower header and bubble them, the bubbles start back over at 1. How can I tie these bubbles back into the BOM that resides on this very sheet?
For example, on the tube bundle plan view, the cap is item 9, but the same cap in the header detail is 3.
I know, I know, I should have them on separate drawings, but we've had a format for fab drawings for years and I have to maintain that.
Thanks for your help!
J.D.
Tube Bundle:
- Tube 1:
Fins
- Tube 2:
Fins
- Tube 3:
Fins
- Header (upper):
Pipe
Cap
Weld Flange
Couplings
- Header (Lower):
Same as upper
J.D.
