BOM to Excel 2003 problem
Teabags
For some reason Catia is outputing blank BOM's in excel. I can save .txt's and html's no problem, but .xls comes out empty. I am running Windows x64 and Office 2003. Is there some setting I am overlooking? Is it a 64bit incompatibility? My coworker can output a BOM into excel without any problem on his 32 bit machine. Any help will be greatly appreciated.
I use this code to pull the BOM into Excel
Dim oRootDoc
Dim oRootProd
Dim assemblyConvertor1
Set CATIA = GetObject(, "CATIA.Application")
Set oRootDoc = CATIA.ActiveDocument
Set oRootProd = oRootDoc.Product
Set assemblyConvertor1 = oRootProd.GetItem("BillOfMaterial")
Dim arrayOfVariantOfBSTR1(11)
arrayOfVariantOfBSTR1(0) = "Part Number"
arrayOfVariantOfBSTR1(1) = "Quantity"
arrayOfVariantOfBSTR1(2) = "UM"
arrayOfVariantOfBSTR1(3) = "Material"
arrayOfVariantOfBSTR1(4) = "NumeroDeCatalogo"
arrayOfVariantOfBSTR1(5) = "ScrewsName"
arrayOfVariantOfBSTR1(6) = "ScrewsQty"
arrayOfVariantOfBSTR1(7) = "ScrewType"
arrayOfVariantOfBSTR1(8) = "DowelName"
arrayOfVariantOfBSTR1(9) = "DowelQty"
arrayOfVariantOfBSTR1(10) = "DowelType"
Dim assemblyConvertor1Variant As Object
Set assemblyConvertor1Variant = assemblyConvertor1
assemblyConvertor1Variant.SetCurrentFormat arrayOfVariantOfBSTR1
Dim NumOfProducts As Integer
Dim i As Integer
Dim oSubProd 'As product
Dim SourceFileName As String
Dim NumOfSubProducts As Integer
NumOfProducts = oRootProd.Products.count
i = 2
For i = 1 To (NumOfProducts)
Set oSubProd = oRootProd.Products.Item(i)
SourceFileName = Folder & "\" & oSubProd.Name & ".xls"
oSubProd.ExtractBOM catFileTypeHTML, SourceFileName
Yes I got it to work by removing service pack 2 from Windows XP64. Works fine in sp1
