Oz46
- Oct 18, 2004
- 5
I have come across an existing exterior masonry wall that appears to be constructed out of 6" concrete block and 4" brick. The building is a 60 years old warehouse building. There is no indication of any bonding between the two masonry members (wythe) and the wall is about 16 ft high. There are some stepping cracks on the brick (exterior) around overhead doors but not many visible cracks on the interior side (blocks).
1) Is there anyway that we can verify if the two wythe are actually bonding? As mentioned I don't see any running bond between the two neither from inside nor from outside of the building.
2) In absence of any existing bonding between the two wythe, is there any suggestion how to bond the existing brick and block without tearing down the whole wall?
Any comments or suggestion is very much appreciated.
