Bonus tolerance in LMC 1
mousepotato
62
I have heard that we get a Bonus tolerance for both MMC & LMC.
It is perfectly clear to me how a Bonus tolerance gets added to the position tolerance of a hole, while it starts to "get bigger" from MMC towards LMC.
But how is this possible with LMC of a hole (See the attached excerpt)?
Beats me...
Any help would be appreciated.
Thanks in advance.
 http://files.engineering.com/getfile.aspx?folder=879c7d2a-53f4-4dc6-9edb-1fdb28811e52&file=LMC_Bonus.jpg
Thanks friends,
Finally the LMC condition makes sense to me on the thin wall scenario.
Correct me if I'm wrong:
If the locating is not important, and the hole and shaft merely need to fit together, I would go for mmc on hole.
If I'm concerned with a hole in a tube which shouldn't get big enough to "eat" the surrounding wall,I would put an LMC on the hole.This ensures a bigger hole "stays" in place while smaller hole can "move around" (like a planetary gear).
If locating is important for a hole and a shaft, then the "play" between them can be arrested by an Lmc modifier.
Any additional scenarios, which call for mmc & lmc?
What do you mean when you give zero tolerance at mmc?
Any examples for RFS condition?
Thanks in advance.
