Alnour,
Ok...a few questions first. Does your company use a PDM tool, such as IMAN, UGMAN, Tce, etc? If so, than all part file names will need to be encoded decoded when used. Not a big deal, but there is the possibility of the encoded part naming being too long
I'm assumming that decent seed files have been used, in so much as consistent CAD standards are used (consistentency! same layering, text height and font, same attribute names, etc.)
The grip I created asked the user how many drawing sheets to add, and would then read the current file to determine the number of existing drawing sheets and add to this number the quantity desired. It would create the dwg sheet at the correct size, add the border on the correct layer, add all of the text at the correct size, position, orientation, attribute, etc. It would then, based on drawing type (casting&machining, assembly, purchased part, detail, etc) add the correct decals to the face of the drawing (advanced release, sign off block, production release decal, uncontrolled copy, etc).
Want more?
SS
