boundary conditions for heat transfert model
21did21
31
Hello world,
i am a beginner and i test to do a easy model on abaqus.
I want to simulate the transient temperature field for a cube which have this dimensions:
1x1x1meter and this characteristic:
-> conductivity: 3.7e-8 ohm.m
-> density: 2700 kg/m3
-> specific heat: 896 J/(Kg.K)
The problem is: i don't know how i have to made my boundary conditions and load:
=> at initial time my cube is at room temperature
=> at step1 the cube is in a oven at 175°C
1°) i try to put all node at 20°C for the initial step
and erase this boundary conditions for the second step and make all the surface at 175°C but my results are very bad:
=> the temperature don't go in the center of my cube in 100000seconds
can you help me ?
The conductivity should be a thermal conductivity not electrical!
unit is W/m/K. For a typical steel its about 30.
Before step 1
*initial conditions, type=temperatur
all_node, 20.
This is NOT a boundary condition!
STEP 1: simulate the cube in the owen by letting it interact with the predefined source temp of 175. This interaction can be modelled via heat transfer *FILM. You have to specify the htc(heat transfer coefficient) W/area/temp_diff, Try the value 10-20 W/m2/K for non-forced convection.
*Film,
surface_name, source_temp(175), htc
The *Film is created in the CAE:
Interaction > surface film condition in a heat transfer step
thank a lot for your help, i will try it !
