Hi Everybody,
i have a down-to-earth problem but could not find the solution.
i am doing the frequency analysis of an optics table, basically made of two granite legs and a granite top. in use, the legs will be resting on the ground without any fixing but restrained in position. the table top will also rest on the legs by gravity without any fixing.
the problem is, in cosmosworks, i am not able to provide 'simply supported' boundary condition. the model is meshed with solid elements and whenever 'no ranslation' is provided it is basically conveted to fixed BC. can this problem be solved in cosmosworks or i am doing some gross mistake?
thanks in advance for any help.
