bounding box 1
jenuary
Good evening
I have a problem with a Journal file for extract the bounding box of the part.
I have this file but doesent work.
For me is very important.
Thank you very much.
By
When you say it doesn't work, do you mean: it doesn't run at all, it errors out, or it gives incorrect/unexpected results?
I see the journal was written with NX6 in mind, what version of NX are you running?
Jenuary,
It looks like this was an unfinished program.
This should run now.
Code:
' NX 6.0.0.24
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Assemblies
Imports System.IO
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim strPart as string
Dim pos as integer
Dim bbox(5) as double
Dim dblAcc_Value(11) as double
Dim dblMass_Props(46) as double
Dim dblStats(12) as double
'''msgbox ("inizio")
        Dim solid1 As Body = SelectSolid()
        If solid1 Is Nothing Then
            Return
        End If
	Dim tagList(0) As NXOpen.Tag
	tagList(0) = solid1.Tag
	'get the full file path
	strPart = solid1.owningpart.fullpath
'''msgbox(strPart)
	pos = InStrRev(strPart, "\")
	'strip off the ".prt" extension
	strPart = Left(strPart, Len(strPart) - 4)
'''msgbox(strPart)
	'add extension to file name for parasolid export
	strPart = strPart + ".x_t"
'''msgbox ("tag: " & solid1.Tag, vbokonly, "Tag")
'''msgbox ("file: " & strPart, vbokonly, "Part")
	'export the solid to a parasolid file
	'ufs.Ps.ExportData(tagList, strPart)
	'get volume
	dblAcc_Value(0)=.999
'''	ufs.Modl.AskMassProps3d(in_Tags(),in_num_objs,in_type,in_units, _
in_density,in_accuracy,in_accuracy_values(),out_mass_props(),out_stats())
'''	ufs.Modl.AskMassProps3d(tagList,1,1,1,.0375,1,dblAcc_Value(), _
dblMass_Props(),dblStats())
	ufs.Modl.AskMassProps3d(tagList,1,1,1,.0375,1,dblAcc_Value, _
dblMass_Props,dblStats)
msgbox ("Volume: " & dblMass_Props(1), vbokonly)
	'get solid body bounding box extents
	ufs.Modl.AskBoundingBox(solid1.Tag,bbox)
msgbox ("min X: " & bbox(0) & "min Y: " & bbox(1) & "min Z: " & bbox(2) & "max X: " & bbox(3) & "max Y: " & _
bbox(4) & "max Z: " & bbox(5), vbokonly)
End Sub
    Public Function SelectSolid() As Body
'''msgbox("passato a solid")
        Dim ui As UI = ui.GetUI
        Dim message As String = "Select solid body"
        Dim title As String = "Selection"
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim keepHighlighted As Boolean = False
        Dim includeFeatures As Boolean = True
        Dim selectionAction As Selection.SelectionAction = _
            Selection.SelectionAction.ClearAndEnableSpecific
        Dim selectionMask_array(1) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = 0
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
            '.SolidBodySubtype = 36
        End With
        Dim selectedObject As NXObject = Nothing
        Dim cursor As Point3d
        ui.SelectionManager.SelectObject(message, title, scope, _
                                         selectionAction, includeFeatures, _
                                         keepHighlighted, selectionMask_array, _
                                         selectedObject, cursor)
        Dim solid As Body = CType(selectedObject, Body)
        If solid Is Nothing Then
'''msgbox("Return Nothing")
            Return Nothing
        End If
'''msgbox("Return solid")
        Return solid
    End Function
End Module
Hi Jpetach,
thanks for the help, it's perfect.
I have a question for you:
is possible to get the total size 3 dimension?
In this exsample i have the minimun en the maximun X,y,Z dimension,
you can get the total dimension without adding parameters minum and maximun?
Sorry for my English, i'm Italian
Have a nice day
Jenuary
