I have a horizontal bracing member under compression load and it is to be connected using a "L-shaped" gusset plate to two beams connected to the column. I am concerned about the plate buckling or folding under the compression load. I think I should be stabilizing the plate vertically so that is cannot buckle. Any one have any experience or reference material on this?
Thanks and Regards!
Thanks and Regards!
