bracing gusset plate design, for compression 1
N Andersen
7
CISC Technical Memoradum No. 5 (2002) notes that designing gusset plates for axial compression only greatly overestimates the capacity of the plate, as eccentricity is negleced.
I would think that a moment = force * 1/2 plate thk. in the weak direction would need to be considered.
Is there a current design method or guide available anywhere?
this is where we got to in strutural forum,
thread507-247873
This is the NZ code, but the basic logic is that the bending length is increase due to the fact taht the connection causes hte braces to act as a sway frame. The design is then treated as a column buckling.
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
nda,
The eccentricity is the sum of 1/2 each plate thickness. I think most of us are now providing stiffeners for these connections.
hokie,
Do you provide stiffeners to one side of the joint or both. I haven't been using stiffeners until the load gets large, and then only on one side of the joint.
In most normal bracing situations, a stiffener on one side should do the job, unless the connections gets quite long.
When I have a need for gussets it is usually for reversal loads (wind), so I make them symetric.
