Mkuchta
Materials
- Sep 29, 2004
- 8
I have an corrosion mechanism in a machineable brass Swagelok fitting (copper,30%zinc,2.5% lead). The fitting has was in use 20+ years in a PH 10 steam environment with <10ppm of hydrazine (which decomposes to ammonia). The part failed at the first thread of the fitting. The fitting appears to be yellow brass colored on the outside with a pink, copper color on the inside. I initially thought it was dezincification however EDX analysis showed almost identical composition in both areas. The only difference was a small increase in oxygen in the copper colored area. The yellow brass area shows a normal microstructure after etching however the pink copper area shows a finely porous surface with no grain structure. If this is not dezincification, what else can it be?
