Brass Valve
ullas2711
26
Hello All,
Is it ok to use Brass Gate Valve (Pegler Make) for under water applications?
What are you going to use it for?
What service fluid?
What pressure and temperature service? (Probably water temp, right?)
What depth water ?
Can you get access to repair it?
What did the company say when you asked them about their valve?
It will be used to regulate the flow to a fountain nozzle
Service fluid is water
Max pressure will be 2 bar and max temp will be around 50 degree celcius (yes water temp)
Water depth is 0.4 mtr
Yes there is access to repair
The company says it is safe to use it
