Breakers in series 1
Mbrooke
2,546
How does one go about controlling two breakers in series? Do I just wire the 52A contacts in series and the trip / close contacts in parallel and program the relaying as with a single breaker or am I overly simplifying it?
Years ago, on sub-transmission, and distribution, there was a thing that was called a reclosing fuse. And not that I would recommend one.
They were used on long out of the city feeders, and would handle lighting strikes, by replacing the blown fuse with a fresh one. But after several strikes it would run out of fresh fuses.
But I doubt that was what David intended in his fuse reclosing comment.
That's just throwing multiple single shot fuses at it. How often would you patrol to see if any of them need to be replaced? I understand that 115kV transformer fuses run several thousands of dollars a piece. Very few operations and the breaker is less expensive.
