Jul 18, 2002 #1 luckym Mechanical Nov 7, 2001 14 SK it is posible to break axis in drawing? (catia v5r9) thanks for help....
Jul 21, 2002 #2 tpale Mechanical Aug 26, 2001 31 FI Hello, You want to 'shorten' it? Insert/Views/Break View/Broken View Regards TPale Upvote 0 Downvote
Jul 23, 2002 Thread starter #3 luckym Mechanical Nov 7, 2001 14 SK No, I want to break this lines (the same way as to break dimension) I want to break axis because intersecting with dimension text. Upvote 0 Downvote
Jul 31, 2002 #4 DABERT Military Jul 26, 2002 3 CA As I know, you can't break an axis, but maybe you can fix your problem as follow: 1- With the icon "AXIS LINE" create a second axis. Now you have 2 axis (AXIS_1 and AXIS_2) 2- CLick on AXIS_1, Press CTRL key while selecting the axis end point above the dimension text and drag it under. 3- Click on AXIS_2, Press CTRL key while selecting the axis end point under the dimension text and drag it above. Voilà DAB Upvote 0 Downvote
