Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
racookpe1978 said:At that size of the claimed large M24 bolt and nut, the METHOD of torquing is critical: You should be applying the torque (which is needed to get the pre-load required for successful operation) in 3 or four stages towards maximum torque (of 25%, 50% 75% 90% and final torque) by a qualified operator using a calibrated torque wrench in a star or hex pattern around the entire joint. Is this being done properly? Have you inspected the operators ACTUALLY DOING the installation? If they are using an air impact wrench to "just drive them down dry" - then, YES. THE BOLTS WILL FAIL.
