Brush Plating Standard for 17-4PH Repair Bushings 1
MS1977
General reference cadmium plating bath processes [for thickness definition, pre-plating surface prep, post plating conversion coatings, etc]: AMS-QQ-P-416 Plating, Cadmium (Electrodeposited) or MIL-STD-870 CADMIUM PLATING, LOW EMBRITTLEMENT, ELECTRODEPOSITION.
Classic brush plating: MIL-STD-865 SELECTIVE, BRUSH PLATING, ELECTRO-DESPOSITION
NOTE. IF hydrogen embrittlement [HE] is a problem [IE: 17-4PH heat treatments ~H950, H925 and H900] then use low HE process solutions.
Precision brush plating process
SAE AMS2451 Plating, Brush General Requirements + AMS2451/4 Plating, Brush, Cadmium Corrosion Protective, Low Hydrogen Embrittlement [for all levels of heat treatment]**
**Note: IF feasible, may want to consider using Low HE zinc-nickel plating per [AMS2417+] AMS2451/9 Plating, Brush, Zinc-Nickel Low Hydrogen Embrittlement.
I believe USAF T.O. 42C2-1-7 has brush plating data.
Also, almost every aerospace company has it's own brush ["stylus"] plating specs [cadmium, nickel, tin, zinc, etc] .
NOTE.
Pre and Post plating [hydrogen embrittlement or stress] relief bakes may be required per AMS2459/11 Stress Relief of Steel Parts and AMS2759/9 Hydrogen Embrittlement Relief (Baking) of Steel Parts. Most LA steels and certain PH CRES alloys that have been heat treated to very high strength levels may/may-not require pre/post plating bakes [NOTE: these relief bake may/may-not be defined in plating specs... better safe than sorry].
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
