robbce
- Sep 6, 2007
- 3
Good Day all,
I had a question regarding a relatively simple problem my boss left on my desk for me yesterday. It is a seemingly simple problem of structural design, however I am missing a few tools to determine the solution. The design problem is to size (find diameter of) an 8' segment of exposed API 5L Grade B pipe based on this situation:
The 8' span of pipe in question is to be exposed piping fixed at one end and free at the other. I need to size the pipe appropriately so it won't buckle under a uniform loading of 322#/ft. I solved for the maximum moment, which occurs at the fixed support, but I don't know how to proceed from here.
I am a Civil Engineer that would otherwise have no issues designing this problem for anything other than round steel pipe (i.e. W, S, HP, C shapes, etc.). But, in my experience, I have never dealt with having to design for pipes acting as beams (only acting as columns with axial loading).
It is my understanding that the info I need to determine the failure modes and stresses of round steel pipe can be found in ASME B31.1 Power Piping (equations for buckling of steel pipe is not found in my bible- AISC Manual of Steel Construction).
If anyone would be able to help me out with the equations for finding maximum/allowable shearing stress, maximum/allowable bearing stress, and/or ways to test for buckling in round steel pipe I would greatly appreciate it.
Thanks very much for any and all of your input,
Rob B., C.E.
Rob B., C.E.
