Bug in Creo concerning point at intersection of two entities?
Not sure if I fully understand, but a couple of questions are how large is the part (model size), and what are the model accuracy settings?
You know, I was never able to get at the Model Size info, even when someone gave me suggestions on how to do so. But just doing a distance measurement, the part is approximately 106" across the widest part parallel to the XY plane. Accuracy is .001. I played with that earlier, and even when set to .01 or .0001, the effect is still the same.
If it is a simple part in Creo 2.0, it will be under tools tab --> investigate (overflow menu) --> model size. And is the accuracy relative or absolute?
FINALLY! Thank you. I think someone else had given me the menu item and such, but for some reason, that menu was not available. Anyway, Model Size is 147.8". Accuracy is Absolute.
