dnonnema
Computer
- Nov 24, 2003
- 7
I have a water issue with my house--it sits at the base of a large hill and my back yard is very wet. My sump pump runs frequently.
I recently installed a french drain at the base of the hill, approximately 20 feet from my foundation (3ft deep, 4" perforated pvc pipe wrapped with fabric sleeve, surrounded with 3/4" clean stone). The drain is working great--water has been flowing out of the outlet pipe constantly since i put it in.
One problem--my sump pump is still running just as much as it ever did. I'm talking about a lot of water--the pump is 3/4hp, 1.5" outlet pipe, runs for about 40-50 minutes every 3 hours.
My question--should I have dug my drain deeper? Do i need to take the base of the drain down to the basement floor foundation level to keep the sump pump from running so much? Should I build a new, deeper french drain parallel (closer to my house) to the first drain I dug?
Also, should I wait for the ground to dry up before I excavate again?
Also, apparently my footing drains are blocked. Is their any way to clean out the footing drains without draining my bank account? :-D
