I have taken a job with a firm that is really just starting a facilities type engineering group. There is currently virtually no library, codes, standards, etc.
I want to make a list of items management should buy. Kind of a wierd situation, generally when you need something you go look for the book, not "what books do I need in case I want to look something up". Off the top of my head, I came up with the following list:
ASHRAE Standards
International Mechanical Code & International Building Code
NFPA
ACGIH industrial Ventilation
Means Estimating Guides
Any suggestions about what you would ad when starting off an MEP library?
Thanks.
ASHRAE Standards
NFPA
Thanks.
