Krausen
- Jan 1, 2013
- 289
Hello All,
I do not normally work in HVAC, so I was hoping to get some direction from the forum on some basic ventilation concepts inside a small industrial building. Basically I have a small one-room Laboratory Shack (10'x24') with a stand alone fume hood inside a Oil & Gas facility. The shack will house a lab fume hood with a ducted ventilation system to atmosphere. The fume hood exhaust will only be turned on when performing lab tests inside it. The shack itself will also have a general ventilation exhaust fan mounted on one wall with intake hoods/louvers on the opposing wall to provide crossflow ventilation through the entire shack. The general exhaust fan will be turned on anytime anyone is inside the shack.
An issue has been raised on checking to make sure the general exhaust fan does not compete with or negate the ability of the fume hood to vent adequately. In other words, when both the fume hood exhaust & general exhaust fans are turned on, both must still vent adequately together. How would one go about analyzing something like this? Is it simply a matter of sizing one fan & system more than the other?
Thank you in advance!
Tolerance is the virtue of the man without convictions -GK Chesterton
