Given a 3-ply sawn lumber bending member (face width oriented for strong axis bending), what width value, "b", would you use when evaluating the Beam Stability Factor, CL, in NDS 2015 3.3.3?
For example: Let's say you have a 3-ply 2x10 bending member. Ignore the possibility that you may have continuous lateral restraint or that you may have something preventing rotation at the member's ends (so CL doesn't default to 1.0). Do you evaluate the CL factor using b=1.5" for one 2x10 and multiply your design capacity by 3? Or rather, do you take b=4.5" and determine the bending capacity of the overall 3-2x10?
Thanks, team.
-Cody
Thanks, team.
-Cody
