TehMightyEngineer
- Aug 1, 2009
- 3,073
Short question: I'm trying to figure out why you can't count the weight of water as resisting the buoyancy force on a buried concrete tank.
Long question: I've attached a picture of my understanding of how the buoyancy loads should work out. The various discussions I can find on here and elsewhere discuss using the buoyant weight of soil which is the soil density minus the density of water. This makes sense to me that the soil will effectively weigh less in water. However, shouldn't we then take into account the weight of water (effectively putting the 62.4 pcf back into the weight) as the water will weigh down the structure.
Essentially, I imagine that there is a block of water the width of the lip of the base slab and the height from the base slab up to the water table. This block exerts pressure in all directions; the vertical force holds up soil above it, the lateral force pushes on either the structure or other water, and the bottom force pushes the structure down (which combines with the weight of soil). Thus, this block is confined in static equilibrium.
Another way of looking at it is to imagine you take the structure and enclose it in a clear glass tank of no weight. To pick up the structure you have to take the soil, structure, and water with it. Now, obviously in real life if we pick it up the water will flow away and leave the soil behind but doesn't the confining action of the surrounding water allow us to take the weight of water into account?
The only example I can find in literature on this is the Portland Cement Association; Rectangular Concrete Tanks, Revised 5th Edition, example 1, page 5-10. This example starts out giving a weight of "moist soil" as 100 lb/cu.ft. and then in the buoyancy calculations uses a "conservatively light" soil weight of 70 PCF. However, it says nothing of taking this reduction to account for the presence of water unless that was already included in the "moist soil" weight; but I find it hard to believe they had a soil with an original density of 162.4 lb/cu.ft. (even 70+62.4 = 132.4 lb/cu.ft. seems high for anything but the most heavy of soils).
Maine EIT, Civil/Structural. Going to take the 1st part of the 16-hour SE test in April, wish me luck!
