Burgmann MFLW 805S 1
smart2006
11
Does any have literature or documentation on Burgmann MFLW 805S.
It should be a specialy designed high temperature metal bellow type single seal. "S" should be stands for special design. You cannot find these type of seals at catalogs. however I dont know what 5 means. and the shaft size is also missing. There is something missing at designation.
Hi.
What kind of mechanical seal I must to use for coal tar (max 80deg C).
I know that it must be double mechanical seal, with API Plan 53. But construction of this seal? Back-to-Back or tandem; bellows or springs. Maby some example from Burgmann or J.Crane.
adula29
Contact your local Burgmann (EagleBurgmann) sales office. They have designs especially for that application that are not in the catalog or guide
Help rescue exotic & endangered birds. Feathered Friends Forever (.org) is the largest non-profit parrot sanctuary in the US, 2nd worldwide with over 800 birds on site.
Check the website & make a donation if you can. I'm on the Board of Directors now.
Yes , like the other said , you should contact the burgmann directly
peter
Mechanical seal
