s2468
Chemical
- Oct 6, 2017
- 6
Hi All,
I have a reactor which has a design pressure of 6.9 barg, where an acid hydrolysis reaction takes place. The batch is reacted to up to a maximum of 125 degrees using a steam heater jacket. The steam comes in at 2.5 barg. The reactor pressure during normal operation is 1.1 barg. The reactor is fitted with a bursting disc which has a set pressure of 2.5 barg upstream of a relief valve which has a set pressure of also 2.5 barg, but I am looking to remove the pressure relief valve and only have a bursting disc where I will replace the current bursting disc. Currently, the relief valve is exposed to vent with an exhaust fan to get rid of the relief gases, so it experiences a back-pressure.
The causes that can lead to overpressure the reactor is the failure of the steam control valve supplying heat to the reactor jacket with the reactor to be blocked in. The steam pressure upstream of the jacket is 2.5 barg and therefore the maximum the reactor can achieve is 2.5 barg which means it cannot overpressurise the reactor.
At present, it is not possible to overpressure the reactor as the maximum pressure of the inlet streams is less than 6.9 barg. But it is good practise to keep a relief device on the reactor. Should the new bursting disc have a set pressure which accounts for the design pressure of the vessel or should It still have a set pressure of 2.5 barg?
Before I remove the relief valve and replace the current bursting disc with an appropriate one, I need to be able to quantify the back pressure the bursting disc will experience due to the exhaust fan to make sure that the bursting disc will be able to handle the back pressure. How can I measure the back-pressure? Would I measure it directly, or use a fan performance curve?
Would greatly appreciate the help
