Hi guys thanks,
For a quite a long time bursting the use of bursting discs have been avoided as a pressure relief device for pressure vassels (not for heat exchangers where it is still good practice to do so) mostly in the oil industry.
So the reasons for not using the b. discs in pressure vessels came up, and as you said(EGT01)and i quote "it is a matter of practical application", for example if the discharge is not routed to the atmosphere but to a "closed circuit" it is not good practice to use b. disc alone( not even as a backup to a relief valve as it is used for normally(open for discussion). Now the reason i asked about any documentation refering to the non use of b. discs in the case of p. vassels is that i'm doing some work on b. discs and during a discussion on that matter it was mentioned that API RP 520 makes reference to that but it doesn't and i can't find it also can't find it in the BS EN ISO 4126-2:2003.
sorry for the lack of clarity when a first "worded" the question.
AND' EGT01 THAT'S AN INTERESTING SITE THANKS.
REGARDS
