Hello.
I am thinking of if there is a cheaper polymer than PEEK for a bushing.
The max surface pressure is 20Mpa 2.9psi.
The motion can be described as slightly pivoting.
And the shape of the bushing is:
Inner diameter = 15mm , 0.6 inch
Thickness = 1.5mm , 0.06 inch
They are going to be injection moulded.
We will do around 300 000 pieces but the most will done in POM for lower temperature applications.
