Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
This is very helpful, thank you! Since it's out of spec on the thicker side (more conservative?), what's the downside to tapering it to meet the requirement of B31.8 when welding it to the Sch80 pipe?Assuming this is a ASME B16.9 fitting, you can check the allowable tolerances from that standard (Table 11-1). Between NPS5 and NPS8, the tolerance on outside diameter is +0.09"/-0.06", while the tolerance on inside diameter is +/-0.06".
Nominal outside diameter for NPS6 is 6.625". With tolerance this could be as large as 6.715".
Nominal inside diameter for NPS6 XS is 5.761". With tolerance this could be as low as 5.701".
Therefore the maximum allowable wall thickness for a B16.9 NPS6 XS fitting would be (6.715" - 5.701") / 2 = 0.507". Your fitting is non-compliant to B16.9 and should be rejected.
The manufacturing process for these types of fittings typically starts with one size of pipe, and then expands or contracts one end to the required size. I suspect they started with NPS8 XS pipe, contracted one end to NPS6 OD, but didn't remove or check the extra material, as the area of the cross section of NPS8 XS pipe is similar to the area of NPS6 pipe with a 0.62"-0.65" wall.
