Bylaser 4400 "Overcurrent on tube 10" 1
dgroff2029
Industrial
Aug 5, 2014
I keep getting this error message on one of our Bystronic lasers. After acknowledging the error and restarting the cut a couple of times it goes away for a few hours. Can someone please tell me where I need to be looking to eliminate this issue.
Krugtech....thanks for your reply. I actually got a tech from Alphatronics in house today to take care of this and several other issues. This forum will probably be my lifeline for awhile though. I spent 14 years in plastic extrusion and due to a plant closure, have found myself working with lasers now. Thanks again for your response.
dgroff,
Let us know what the tech finds, I find it very helpful to search old threads when I have issues, and it is great when I find a solution in a thread.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
Krugtech is right! Overcurrent happens because of gas contamination, leak (check the yellow hoses), humidty (check dehumidifier) e gas quality.
Overcurrent tube.
I had exactly the same problem.
Yesterday I wanted to ask for advice.
I can advise you....... Today.[glasses]
Vacuum test in okay. (20 minutes) . Power okay. No other visible problem.
Through it all 2 x or 4 x daily failure. ,,overcurrent tube - 10 or 8"
The entire month..... Twice came Service.
Test the quality of helium and nitrogen - OK.
We tested the volatility of the electricity supply.
All for nothing
We found the cause of the problem.
You disbelieve...... With cooler water leak..... minimum leakage.
Cooler in High-voltage cabinet. Above insulated plate vacuum tube and semiconductor diodes.
Just drop of water which is immediately evaporated.
!!!! Caution - high voltage can kill !!!
Sorry for poor English.
I just repairman agricultural and forestry machinery. From the Czech Republic [bigsmile]
I speak only Flemish, Czech, German and Russian with resistance.
Stanley
Your English is fine. In fact it is better than some of the people I work with who were born here in the States.
