C# Programming
Kishor khalane
IN
Hello Guys,
Below is the code for two cylinder in C#. Please tell how to UNITE this 2 cylinder
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using NXOpen;
namespace cylinderbuilder
public class Class1
public static void Main()
Session theSession = Session.GetSession();
Part workPart = theSession.Parts.Work;
Part displayPart = theSession.Parts.Display;
NXOpen.Features.CylinderBuilder cylinderbuilder;
cylinderbuilder = workPart.Features.CreateCylinderBuilder(null);
// Specify the cylinder definition type(AxisDiameterAndHeight)
cylinderbuilder.Type = NXOpen.Features.CylinderBuilder.Types.AxisDiameterAndHeight;
// Define the Cylinder Axis
Point3d origin = new Point3d(0, 0, 0);
Vector3d vector = new Vector3d(1, 0, 0);
Direction direction;
direction = workPart.Directions.CreateDirection(origin, vector, SmartObject.UpdateOption.WithinModeling);
Axis axis;
axis = cylinderbuilder.Axis;
axis.Direction = direction;
// Define Cylinder Diameter
string diamString = "100";
cylinderbuilder.Diameter.RightHandSide = diamString;
// Define Cylinder Height
string heightString = "20";
cylinderbuilder.Height.RightHandSide = heightString;
// Define the boolean option (Create, unite, etc.)
cylinderbuilder.BooleanOption.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Create;
// Destroy the builder to free memory
NXObject cylinder = cylinderbuilder.Commit();
cylinderbuilder.Destroy();
// Another Cylinder
NXOpen.Features.CylinderBuilder cylinderbuilder1;
cylinderbuilder1 = workPart.Features.CreateCylinderBuilder(null);
cylinderbuilder1.Type = NXOpen.Features.CylinderBuilder.Types.AxisDiameterAndHeight;
Point3d origin1 = new Point3d(20, 0, 0);
Vector3d vector1 = new Vector3d(1, 0, 0);
Direction direction1;
direction1 = workPart.Directions.CreateDirection(origin1, vector1, SmartObject.UpdateOption.WithinModeling);
Axis axis1;
axis1 = cylinderbuilder1.Axis;
axis1.Direction = direction1;
string diamString1 = "110";
cylinderbuilder1.Diameter.RightHandSide = diamString1;
string heightString1 = "30";
cylinderbuilder1.Height.RightHandSide = heightString1;
cylinderbuilder1.BooleanOption.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Create;
NXObject cylinder1 = cylinderbuilder1.Commit();
cylinderbuilder1.Destroy();
public static int GetUnloadOption(string dummy) { return (int)NXOpen.Session.LibraryUnloadOption.Immediately; }
Change the following line
To
cylinderbuilder1.BooleanOption.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.unite;
Didier Psaltopoulos
Hello Didier Psaltopoulos Sir,
Thank for your help.
I tried this as you wrote that change that line.
But I didn't get unite those cylinderbuilder.
If you have any other please kindly share.
Kishor
Didier mean to change only for
The second cylinder.
If you done this and fail.
Try record a journal for the unit
Of two cylinders.
If possible and you have code for uniting 2 cylinder in VB.
you could possibly share it for understanding purpose.
Because C# and VB is somewhat similar.
I know basic knowledge of VB also.
Thank You
Here is code in VB for hole generation but it is getting ERROR.
Please suggest where to modified this code.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module HOle
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim ufs As UFSession = UFSession.GetUFSession()
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Public Sub Main(ByVal args() As String)
Dim markId1 As NXOpen.Session.UndoMarkId
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
'How to make body select??
Dim body1 As NXOpen.Body
body1 = SelectSolid()
Dim itargetBodies(0) As NXOpen.Body
itargetBodies(0) = body1
If Not workPart.Preferences.Modeling.GetHistoryMode Then
Throw (New Exception("Create or edit of a Feature was recorded in History Mode but playback is in History-Free Mode."))
End If
CreateHole(0, 0, itargetBodies)
CreateHole(15, 0, itargetBodies)
CreateHole(30, 0, itargetBodies)
End Sub
Sub CreateHole(xcoord As Double, ycoord As Double, targetBodies As NXOpen.Body())
Dim nullNXOpen_Features_Feature As NXOpen.Features.Feature = Nothing
Dim datumCsysBuilder1 As NXOpen.Features.DatumCsysBuilder
datumCsysBuilder1 = workPart.Features.CreateDatumCsysBuilder(nullNXOpen_Features_Feature)
Dim cartesianCoordinateSystem1 As NXOpen.CartesianCoordinateSystem
cartesianCoordinateSystem1 = workPart.WCS.CoordinateSystem
'Define origin
Dim orPt As Point3d
orPt.X = xcoord
orPt.Y = ycoord
orPt.Z = 0
'New origin for CSYS
cartesianCoordinateSystem1.Origin = WCS2Abs(orPt)
datumCsysBuilder1.Csys = cartesianCoordinateSystem1
datumCsysBuilder1.DisplayScaleFactor = 0.5
Dim nXObject1 As NXOpen.NXObject
nXObject1 = datumCsysBuilder1.Commit()
Dim datumCsys2 As NXOpen.Features.DatumCsys = CType(nXObject1, NXOpen.Features.DatumCsys)
'Need to select datum origin.
Dim point1 As NXOpen.Point = CType(datumCsys2.FindObject("POINT 1"), NXOpen.Point)
'Dim point1 As NXOpen.Point = CType(datumCsys2.Location, NXOpen.Point)
datumCsysBuilder1.Destroy()
'Create Hole Part
Dim nullNXOpen_Features_HolePackage As NXOpen.Features.HolePackage = Nothing
Dim holePackageBuilder1 As NXOpen.Features.HolePackageBuilder
holePackageBuilder1 = workPart.Features.CreateHolePackageBuilder(nullNXOpen_Features_HolePackage)
'Point
Dim points1(0) As NXOpen.Point
points1(0) = point1
Dim curveDumbRule1 As NXOpen.CurveDumbRule
curveDumbRule1 = workPart.ScRuleFactory.CreateRuleCurveDumbFromPoints(points1)
Dim rules1(0) As NXOpen.SelectionIntentRule
rules1(0) = curveDumbRule1
Dim nullNXOpen_NXObject As NXOpen.NXObject = Nothing
Dim helpPoint1 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
With holePackageBuilder1
.HolePosition.AllowSelfIntersection(True)
.HolePosition.AddToSection(rules1, nullNXOpen_NXObject, nullNXOpen_NXObject, nullNXOpen_NXObject, helpPoint1, NXOpen.Section.Mode.Create, False)
.BooleanOperation.Type = NXOpen.GeometricUtilities.BooleanOperation.BooleanType.Subtract
.BooleanOperation.SetTargetBodies(targetBodies)
End With
'Hole Type 6
.GeneralHoleForm = Features.HolePackageBuilder.HoleForms.Simple
.HoleDepthLimitOption = Features.HolePackageBuilder.HoleDepthLimitOptions.ThroughBody
.GeneralSimpleHoleDiameter.RightHandSide = "6"
.GeneralSimpleHoleDepth.RightHandSide = "12"
.Tolerance = 0.001
End With
'Commit Hole
Dim nXObject2 As NXOpen.NXObject
nXObject2 = holePackageBuilder1.Commit()
holePackageBuilder1.Destroy()
End Sub
Function SelectSolid() As Body
Dim ui As UI = ui.GetUI
Dim message As String = "Select solid body"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = True
Dim selectionAction As Selection.SelectionAction = _
Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
Dim selectedObject As NXObject = Nothing
Dim cursor As Point3d
ui.SelectionManager.SelectObject(message, title, scope, selectionAction, includeFeatures, _
keepHighlighted, selectionMask_array, _
selectedObject, cursor)
Dim solid As Body = CType(selectedObject, Body)
If solid Is Nothing Then
Return Nothing
End If
Return solid
End Function
Function Abs2WCS(ByVal inPt As Point3d) As Point3d
Dim pt1(2), pt2(2) As Double
pt1(0) = inPt.X
pt1(1) = inPt.Y
pt1(2) = inPt.Z
ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_COORDS, pt1, _
UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt2)
Abs2WCS.X = pt2(0)
Abs2WCS.Y = pt2(1)
Abs2WCS.Z = pt2(2)
End Function
Function WCS2Abs(ByVal inPt As Point3d) As Point3d
pt1(0) = inPt.X
pt1(1) = inPt.Y
pt1(2) = inPt.Z
ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt1, _
UFConstants.UF_CSYS_ROOT_COORDS, pt2)
WCS2Abs.X = pt2(0)
WCS2Abs.Y = pt2(1)
WCS2Abs.Z = pt2(2)
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
Thank You
End Module
