Miley223
Aerospace
- Feb 21, 2023
- 3
So to me a cable drawing is when you have multiple wires bundles together.
I have this flanged connector. So the house power cable is not long enough to reach our panel. so i have to build a cable that could get me from one panel to another panel on rack.
so i showed photo below. to build this cable i would have to attach the flanged connector to the panel first before i could attach the wires from connect to connector. These wires will be encompassed by a rubber sleeve.
i was going to create a cable drawing to show how this would all be built. i was going to have a note saying connector must be mounted on the panel first to build the harness.
I had someone mention this is a wiring diagram and not a harness since the connector has to be put on the panel first. definitely not the best design i will agree but it was a part we had on hand. would it be cable drawing or a wiring diagram?
to me a cable is a bundle of wires. a wiring diagram could represent a bunch of wires loose and not bundles together.
In addition, are there drawing standards for this. I did find much in the ASME standards on cable or wiring diagrams.
