nkn5
- Dec 25, 2010
- 34
Incase of a cable feeding power from one switch-gear to another one, I understand that the cable better shall be sized as per the least of outgoing breaker of later and incoming breaker of the second one. But sizing as per the connected load on the downstream swgr is not a good practice as we are trying to size on some thing which can change.
Now, Can any one suggest if any standard (IEC / ANSI) requires to be done this way or is it just a good practice followed?
Thanks in advance
Thanks in advance
