Dakka
- Feb 2, 2022
- 4
Hi.
Consider a cable-stayed bridge. The side span consists of 18 segments and the midspan has (16 segments + Stitch segment + 16 segments)
The adopted construction sequence is the following:
From the Pylon, 16 segments are cast on both LHS & RHS sides, completely supported on Formwork.
Then the 8 Stay cables are stressed one after the other.
After stressing all the stay cables, the formwork is removed.
Optimization is done in this stage, by fixing the Stay cable forces to restrict the BMD of the Superstructure to a good profile.
Then the Abutment segment (Seg 17&18) of sidespan are cast thereby finishing the sidespan.
Now, the Stitch segment of Midspan is cast.
Now, the SIDL & WC are laid. This generates a Not so good BMD.
Now, Second stage prestressing is adopted for all the stay cables to acquire an optimized good BMD.
The goal of the problem statement is to decrease the Stay cable forces while still maintaining an optimized Bending moment of the Superstructure, because the Stay cable costs are very much higher. Are there any methods to optimize the Bending moment of Superstructure? Meaning which would replicate the action of stay cable force? Such as using a Ballast load in Midspan before casting stitch and removing it after stitch is cast? Or Support lowering?
(PS: Pin bearing in vertical direction is considered as support for side spans)
Thanks in advance,
Dakka
Thanks in advance,
Dakka
