Cable Tray Impedance
TTUEE
8
0
0
Does anyone know of a reference showing how to calculate impedance of 600V cable in a flat configuration in cable tray, specifically the inductance?
But if you know effective impedance of cables why do you need to know more about?
I think that any book of distribution could help you a lot to study it more, they convert all values to secuence impedances
If there was no electricity there would be no internet. Good point, don´t you? :D
Because the cable configuration affects the mutal impedance and the grounded tray would affect the zero sequence and I haven't found in any book.
As customary in such cases is to use the effective impedance value for calculating the voltage drop
in any event that affects the type of installation is the maximum demand that can be applied to the feeder
