CAE: Response Analysis
aidangoggin
8
Hi all,
I'm very new to ABAQUS and i am having a bit of trouble setting up a dynamic analysis.
I'm trying to recreate a harmonic response test of a model. I have the modal analysis completed and the results are satisfactory. I now wish to recreate the test peformed on the vibration bed.
It is a swept sin test from 10Hz to 100Hz, magnitude is 1.5G. Can I do base excitation in CAE? and if so what analysis, loads, amplitudes etc should i use?
Thanks in advance.
You might be interested in:
ABAQUS Analysis User's Manual
-> 6.3 Dynamic stress/displacement analysis
-> 6.3.10 Response spectrum analysis
Hi xerf,
Thanks i will give that a try.
I may be back :)
Hi, haven't been back to this in a while,
can someone assist in helping me defining a SPECTRUM that sweeps from 10Hz to 100Hz. Can it be done? Is there any other method that can be used?
I have been trying do define one with no luck.
Also how do i view the results as CAE only shows one step.
