CAESAR SIF Question
Ccorvera
4
Simple question: Does CAESAR ii calculate SIF's based on B31.3 Appendix D, or B31J? Does it vary by which version of CAESAR you are using? If so, where does this cutoff begin?
Thanks!
Check this out.
From the C2 Quick Reference under the What's New section
CAESAR II Version 13.00
B31J
  • Added support for ASME B31J - 2017 for stress intensification factors (i-Factors) and flexibility factors (k-Factors) in the 2020 editions of the ASME B31.1, B31.3, and B31.9 piping codes. Supports the optional use of B31J with other metallic piping codes. See SIFs & Tees and Bend. (RI-TX-36876)
  • Integrated ASME B31J SIFs and flexibilities into the software. See Bend, Reducer, SIFs & Tees, Bend SIF Scratchpad, Intersection SIF Scratchpad, Miscellaneous Data, and B31J Methods. (RI-TX-36876)
  • Integrated ASME B31J SIFs and flexibilities into Static Analysis. (RI-TX-36876)
  • Integrated ASME B31J SIFs and flexibilities into Miscellaneous reports, including display of default values used in calculations when input values are outside of allowed B3J ranges. (RI-TX-36876, CR-TX-40240)
  • Added options for applying B31J SIFs and flexibilities to the Configuration Editor. (CR-TX-37436)
  • Removed the outdated calculation modules SIFs @ Intersections and SIFs @ Bends, which are replaced by the new B31J integration. (CR-TX-39928)
  • Added a B31J Methods technical discussion to the help. (RI-TX-36876)
Once you have V13 and later, it appears it would use B31J. Before that it would be via App D and the B31J tool if installed.
Thanks both for your answers! This clears things up.
