Calculate shaft diameters
Aled87
Automotive
Mar 1, 2010
24
I have a fixed compound geartrain design consisting of an input gear of 44teeth, a second and third gear joined on a layshaft with 14 and 44 teeth respecively and an output gear of 14 teeth. GR1=44 GR2=14 GR3=44 GR4=14.
My question is how do i work out appropriate shaft diameters when a torque of 480Nm is on gear 1? I have worked out the gear geometry: pcd, module all that stuff.
Iv'e not worked out the speeds yet i also have ideas for bearings but i need the shaft diameters to work out suitable sizes, any ideas? textbooks? calculations?.
thanks
Aled87,
The most basic consideration with gear shaft diameter is the limit imposed by the smallest gear's root diameter dimension.
That would be a good start. Then you must consider the combined shaft stresses from bending and torsion.
Good luck.
Terry
