mottt
Industrial
- Sep 6, 2007
- 90
i got a generator with the next excitation: 35 V dc and 8 A dc, and i´m looking for the transformer that feed power to the dec200, i was thinking on use a 660/120 V transformer but i wonder about the VA needed?
how do you see my calculations?
Excitation volts at full load: 35 V
Excitation amps at full load: 8 A
Excitation amps on short circuit: 24 A
Excitation volts on short circuit: 105 V
The formula i got is:
volts on short circuit*amps on short circuit* ratio input voltage/output voltage* ratio input amps/output amps*1,05*(voltaje short circuit/voltage full load)
this means 1162 VA, on monophasic way... maybe i use a triphasic maybe i could divide by square 3
