67kato
- May 1, 2007
- 5
I am in the process of designing a retaining wall to replace a failing wood rr tie wall. There is an existing inground pool within 8 ft and behind the proposed wall. The top of the new wall and the pool are at the same elevation. The bottom of the new wall is approximately 7 ft down (which includes keying it into the original grade by 1 ft). The backfill will most likely be 1" stone. I am planning on specifying a Redi-Rock segmental gravity wall for simplicity and ease of construction.
There was a time when I could remember how to calc these passive/active loads but it is escaping me. Any help would be appreciated.
Thanks,
John
Thanks,
John
