DerekCoffyn
- Apr 7, 2011
- 3
How does someone calculate the change in size of a pvc part once it is saturated with water? I understand that it is easy to find the "Water Absorption %" of PVC, but this tells me nothing. Is this % based on mass or volume, and does this directly translate to a proprotional change in dimension? If not, then how do I calculate the size change? Also, how do I calculate the time required to saturate my parts prior to final machining? My parts will be permanently submerged in HCL solution so I hope to saturate prior to final machining for best fit? These parts will be about 5 feet long, so dimensional change could be significant.
Thanks to any and all who provide help,
Derek
Derek
