Calculating Closing opening times of pneumatic actuators in combination with solenoid valves
Michel1967
1
does somebody have a simple calculation solution for calculating the closing time of the below mentioned single acting (spring to close) pneumatic actutator
in combination withe a norgren solenoid valve
the pneumatic actuator is a Air-torque actuator type SC00600-4 (spring to close)
supply pressure is 4 bar
(for detail information see Attachment)
The solenoid has a flow of 340 l/hour
thanks for your help
Michel
 http://www.airtorque.de/share/index.php?get_action=open_file&repository_id=6261d67b44e3ea564d1c88d81738abc7&file=%2FEDITION_2010%2FDR_SC_90%2FDRSC00600U-E.pdf
