310toumad
- May 12, 2016
- 63
If I had a steel bolt being threaded into a tapped hole of a softer material, aluminum for example, how would I go about calculating the maximum allowable torque on the fastener assuming I have enough thread engagement? In this scenario, the only failure I can see is the internal threads in the aluminum hole eventually shearing. My approach was going to be to calculate the shear area of internal threads using the formula (6) on page 1537 of the machinery handbook. You can also find it at the bottom of this page:
Then, if I know the yield strength of the aluminum I can calculate the shear yield strength (Ssy = .58Sy) and use that as my threshold for finding what maximum allowable axial force in the bolt can be:
.58Sy = F/As where F is the axial force and As is the shear area derived from the formula above. Once I solve for the axial force I can use the general formula T = KFD to find the corresponding torque value. Does this strategy sound like a reasonable approach?
