Calculating NPSHA 3
Smackavelly
9
On a stripper tower, does the vessel pressure equal to the vapor pressure of the process?
Thanks fellas for all the help... I appreciate all your help and through experience will one day pass it forward. .... After reading your response, I would agree with katmar. I have a diesel reboiler stripper type that is boiling and flashing gasses off the top, going through a condenser and into a reflux drum. the reflux drum in itself is a flash drum sending both liquid back into the stripper top and flashing vapors off the top. Since the process is boiling it would be safe to say that the pressure in the vessel is equal to the vapor pressure.
Yes, I think it would be reasonably safe to say that.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
