If I am pumping a tank of water up to a free outlet (lagoon) I was wondering if I am calculating the pressure in the pipeline correctly.
based on the selected pump curve I figure out the operating point for that pump with the system. For this example say it is 300 GPM @ 30' of total head the pump needs to handle.
would the pressure in the pipe simply be [(30')(62.4 lbs/cu.ft.)]/144 = 13 psi?
Thanks,
Thanks,
