willwoll100
Automotive
Hello guys and gals I'm brand new to the forum and have question, here goes;
I've done a torsion test on a car chassis with one end secured and the other end attached to a device which has a bar connected perpendicular to the chassis which rests on an arced section of steel on the floor. Now the arced section was placed centrally to the chassis and a load applied on the end of the bar. There was 6 DTI's set up at various points of the chassis (3 either side) and the deflection was taken. Now this was repeated when the shear plates were removed and only the top one in place then only the bottom. So the data that I've got is the load applied, angle of twist, radius of twist, distance from fixed point to load applied and deflection. Now what I was wondering is, does anyone know how to calculate the torque of the chassis per degree, I know how to calculate it for simple round bars/tubes but am confused on how to do it for a chassis. Any help would be very much appreciated.
Will
Will
