Calculation example for a 1 sided threaded stud in to a plate
chorner26
Petroleum
Mar 24, 2008
38
Lets say I have a 3/8" diameter threaded stud with a nut on one side, going into a 1/2" thick 36ksi steel plate.
How would I calculate the capacity.
Plan checker says AISC only addresses a nut or mushroom head on both sides.
How it looks, and how it is loaded? You probably do not have clear shear plane, but bending the rod.
Plan checker is correct - bolt shear strength (even bolt bearing) depends on the confinement that comes from a snug tight bolted connection. That's why the pin equations exist - for when you have a pin or bolt without the confinement of the nut and bolt head.
(r13)It is loaded in pure shear with the load coming in right at the plate interface. See attached.
(PhamEng) Do you have a design example that I can look at. The plan checker wants me to follow exactly something put out by AISC or AISI?
 https://files.engineering.com/getfile.aspx?folder=8bb08539-a3b2-4277-ab10-a54ab33ccd43&file=scan0905.pdf
chorner,
Plug weld the shank to the plate, then there is a defined failure plane with single shear capacity calculated as usual.
What are the constraints here? Can we help you figure out a better solution?
My understanding is that threads in mild steel aren't worth much. But with only 600# you're not asking for much either. And AISC won't have a solution here. (at least that I'm aware of)
I'd probably weld a threaded stud on and skip the hole entirely.
I'm not sure what you're trying to accomplish. Does that say Bondo?
I'm not getting why this is a problem. Once the nut on the far side is installed how is this any different than bolting a part to a tapped plate?
Yes it does says bondo for sealer for the out side of the plate. I would love to use a welded stud and skip this but it is already installed. (XR250) what is a design example for bolt into a tapped plate. That is exactly what we are doing.
Try drill and insert shear keys to jam the shank in the plate.
Not aure I have one on hand, but your car's wheel lug bolts seem to work pretty well.
Seems to me as long as your plate is the thickness of a standard nut then the capacity would be a least as good as a single-shear, bolted connection.
