I would like to know the calculation for finding the time to drain a static, atmospheric tank of water to a pit, which is also at atmospheric pressure. Can anyone help? Please include friction loss and minor losses.
Thanks for information. I had looked at the site you gave me, but I was also looking for the actual calculation so that I can check the answers by hand.
Formulas fail when vortices form. A vortex may form when:
-The liquid is falling at a rate of more than 1 m/s
-When the outflowing speed is greater than 3 m/s
-When the level is low
-When the drain connection is located away from the tank
walls in large diameter tanks
-When there are large quantities of gas dissolved in the
draining liquid
-When the liquid inlet induces rotation
-When the liquids are near their boiling points
-When Coriolis effects may somehow influence the flow
If vortices are a problem, a simple breaker of two baffles at 90 degrees attached to the inlet, projecting one pipe diameter (D)above and one D into the inlet has solved the problem for me. The portion above should be about two D wide.
