Calculation of magnetic moment from cored solenoid
MrMagnetic
Military
Aug 1, 2002
4
0
0
SE
Can anybody inform me how to calculate the magnetic moment of (not field around) a solenoid coil wound on a tubular iron core? I´d also like to know how to check that the iron doesn´t go into saturation.
I´m a little embarrassed to ask since I have a M. Sc. in electrical engineering, but I just can´t make anything useful out of my textbooks or previous experience.
Many thanks in advance
MrMagnetic
If you'll let me have your e-mail address, iii mail a microsoft document version of my suggestion to you. I can be reached at mowete@hotmail.com.
cheers!
alexike
To answer those questions you have to characterize your material.
You can calculate the solenoid field easily enough H~NI/L
N=number of turns in length L
I=amperage
L=Length of winding
Whether saturation occurs is a matter of the coercivity of your material. some materials saturate (technically) at very small fields.
if you are performing ac measurments saturation is easily identified: at saturation the current is limited by the impedence of the coil wiithout iron present.
some of the best reference material is in the form of transform design equations.
The magnetic moment of a magnetized cylindrical bar is covered in most EM texts (physics) and should not be a major problem.
